Clears the OSPFv3 counters (statistics).
| all | Specifies all VLANs, tunnels, areas, neighbors, or virtual-links. |
| vlan_name | Specifies an IPv6 configured VLAN. |
| tunnel_name | Specifies an IPv6 tunnel. |
| router-identifier | Specifies a router identifier, a four-byte, dotted decimal number. |
| area_identifier | Specifies an OSPFv3 area, a four-byte, dotted decimal number. |
N/A.
The global command clear counters also clears all OSPFv3 counters. This global command is the equivalent of clear ospfv3 counters for OSPFv3.
This command can be used to clear various OSPFv3 counters (Interface, Area, Virtual-Link, System etc.). The following is the list of various counters that would be reset to zero by this command:
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
